ruff stuff "Y" Link Steering Using GM 1 Ton TRE
Divh
bloomsburg PA
1949
Has anyone used the "Y" Link Steering Using GM 1 Ton TRE kit from ruffstuff and if so how did you like it any complaints i thinking getting it for my 93 ranger when i lift it vs getting skyjackers 6'' lift pitman arm
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i like it.
what are your intentions?
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
That only works for solid axles not ttb.
I like mine. Works good.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Divh
bloomsburg PA
1949
i figured i would have to mod it to work with the ttb and i going for something that wont limit my flex and will handle on and off road well any other good options out there and tnak you for responding
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Do a search for the linkage Stonecrusher was making for awhile. Several reports were it didn't fully cure bumpsteer (though it did alleviate the issues with excessive tire wear).
IMO, a K-link style setup (modified Superlift, etc.) has more to offer than anything else except maybe on a long-travel prerunner suspension (in which case you want to use a crossover or swingset style linkage).
Divh
bloomsburg PA
1949
thanks think i will go with a custom k-link style set up
