Fords4Us
- Dec 27, 2012
- 2
- Snohomish, WA
- Ford Ranger
- Engine Size
- 2.8L
Good afternoon all. I just finished up the duraspark conversion on my '83 Ranger with the 2.8L engine, and so far the road tests have gone pretty well. I have good power throughout the RPM band, nice, smooth, even throttle response, improved efficiency over my previous emissions-on-their-way-out TFI ignition system, and no performance hiccups under heavy load. I would have considered myself done and satisfied, except for an issue which came up during load testing.
My first real engine load test was going up a long moderately sloped hill, which my truck completed with ease. I got to the top and drove a few more miles, with occasional up- and down-shifts, to the next batch of hills. I was about to test on a steeper hill, the steepest in the neighborhood, when I noticed that once in awhile my engine RPMs would stay elevated even after I put in the clutch. This had not occurred prior to my hill test even though I did quite a bit of driving, with shifting all the way through the gears, prior to that particular test. The engine temp was rock solid at normal throughout this period of time, and the engine itself never gave any indications of trouble, other than the slight increase in RPMs. It wasn't racing, but it was definitely higher than idle. If I just coasted awhile, it would not come down on its own. If I goosed the gas just a little, it would come back down right away. Then a little while later, it would happen again.
I decided to skip any further testing for the afternoon and just head for home. The only thing I can compare this to, is the accelerated cold idle speed when first starting up and then goosing the engine to knock the carb off the cold idle setting. But this happened well after the engine was at normal operating temps. Does anyone have any suggestions for why this is occurring and how I can correct it? Thanks as always........
