- Nov 6, 2008
- 16
- Federal Heights, Colorado
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- ~10
- Tire Size
- 35
I've installed a new camshaft synchronizer using the alignment tool at #1 compression tdc (removed #1 spark plug, put finger in the hole and turned the crank until air came out then lined mark on harmonic balancer I0 with tab on crankshaft sensor) and after reinstalling it several times with the tool it came with, a Cardone tool I borrowed from AutoZone(both of which still allowed it to over clock a little), and by lining it up by eye I've think I've got it I go to start it and it idles rough. How critical is the perfect alignment? Is the rough idle related to the synchro? Help! I've got 10 hours on this.
2000 Ranger 4.0L OHV
