Rough, High Idle, Ticking -> Head Disassembly & Update
DirtBronco
25
Georgia
Bronco II
interesting... so I should probably be worried that there was nothing connected to it?
rusty ol ranger
2.9 Mafia-Don
7,759
Michigan
177 CID
Nah. Unless you dont know how to read a dipstick lol
DirtBronco
25
Georgia
Bronco II
While looking through the cam tunnel beneath the lifter valley, I found a catastrophic crack across a cylinder jacket. That would explain all the coolant in cylinder 6 with no noticeable break in the head gasket. Naturally I needed to find another block. Went to a junk yard and pulled another 2.9.
Although the heads don't look too nice, the block itself was pretty good. Rockers were in pretty good nick but I left those for another poor soul who dares submit to the 2.9.
49783
Tach on the donor Ranger said 22XXX and I'm hoping there was only a 1 before that. Jaws of life were taken to the roof so it gave me hope this was a running block before the vehicle's demise.
49784
Much cleaner than the one I got. No soot build up on the crank and the lifters and pistons actually fell out when i rotated the engine upside down. Either recently rebuilt or I'm just lucky... Or both
My dumbass thought to get the "block" price at the yard, it had to just be just the block. Cashier told me otherwise so now I've got 2 cranks, 2 cams, 12 pistons, and double all the other stuff.
49790
The new block has a cast date of 5/87, but I've still retained the heads off the old one with a cast date of 10/89.
Despite them saying 86TM, they are the improved design with the square pedestals.
49786
If your rig has some obvious wear on it, the heavy duty clamp from Advanced is much better than the tiny claw clamp you rent from other shops. Every time I would clamp down with the economy ones, it'd just push the valve down.
49777
Even with the better compressor, I had to wack the retainer with a hammer and socket to loosen the keepers but as you can see, I'm not too pressed to be keeping the old valve... Those hi-flow ones from SI are starting to look like a good idea.
49785
We're all aware of Ford's awful QC department during the time they made these parts, but please tell me this isn't a product of that... Sand in the valve ports?
49788
49789
Also, thats not a crack between the valve ports. Just built up crap. Picture doesn't have any depth.
With the super-duper fancy new cam coming in, I'm gonna opt for heavier duty springs so realistically all I'm keeping are the retainers and keepers.
49787
Machine shop tomorrow. But actually.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Nope.
Google what it does. 😘
DirtBronco
25
Georgia
Bronco II
Oof.. yeah I was thinking of doing that. The factory grey isn't pretty enough for me.
Can't promise it'll be yellow tho, might clash with the red engine bay.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Lol. Glyptal is an insulation paint for armatures in large a/c motors.
When properly applied to cast iron and cast aluminum, it completely seals the surfaces and allows oil to return to the pan without pooling.
Smokey Yunick started the trend in racing. Worth a Google.
