Lets try this again, hopefully this time in the right thread!
I despise rodents... constant battle... have a nest under the upper intake manifold on my '00 Explorer now... Had a pesky varmint in the F350 over the spring/summer and put one of these trap boards in the passenger floorboard and caught one... It's just a chunk of plywood with a bunch of mouse traps screwed to it opposing eachother, then a Tee nut up from the bottom with an allthread handle. No bending down, the traps are easier to set attached to a board... I just put some peanut butter under the little hook in the middle of the paddle and in the little rectangle box thing by the pivot, I started putting some sunflower seeds in the void in the middle. I've also done the same size board with I think 7 rat traps to catch the rats in the wood shed... worked fine. To use this outside you could take a rubbermaid tote and cut slits in the sides and slide it over the handle and use a nut to hold the bin up or something
I'm currently trying to get to a bigger rodent that's plugging the culvert under the road... big ol flat tailed guy I'm pretty sure...
