Right part?
mud junky
22
NH
2.9L/4.0SOHC
i needed a replacement part for my FM-146. a co-worker of mine had the part i needed, but for a different transmission, but says there all the same part. the part is the quick connect for the clutch fluid line were it goes into the bell-housing. his Ranger that the part was for is a 98 2wd. not sure if its the 4 banger or the 3.0l. but he was convinced the part is the same for all the transmissions. do i have the right part?
They are all the same in a given year from 88 on. IIRC there is a year where they changed the fitting and it was between 91 and 98, but I don't remember when exactly.
mud junky
22
NH
2.9L/4.0SOHC
so assuming the change in the parts was not till 98' then im good, but before that i am screwed?
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
I want to say it was '93 it changed, but I can't say for sure exactly.
I'm almost positive it was within the years '88-'98 though, I would not count on what you have working.
