Right hand thread?
Walksnotruns22
23
Washington
Mazda B4000
So this may be a very dumb question. I am trying to remove the clutch fan from my 94 Mazda b4000 4.0 and the fan shroud says right hand thread.
Is it right had thread as I look at the engine from the grill or right hand thread as it I was sitting in the driver's seat?
Thank you in Advance
RobbieD
2.9l Mafia
3,593
Georgia
By the time I figure out front or rear, I then can't remember which is my left hand and which is my right.
I have always used the fan's direction. Hood up, start the motor and see which way the fan turns. The fan clutch will thread off in the opposite direction.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,881
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Front should always be as if you are in the driver's seat looking forward.
Like RobbieD said, the thread should be opposite of the direction the fan turns so that the forces acting against it are always trying to tighten it, rather than loosen it.
ericbphoto
Overlander in development
16,793
Wellford, SC
6"
Clockwise as viewed from a tangent to fibonacci's azimuth while facing south in a class 5 blizzard, simultaneously drinking yak milk from a glass slipper.
Ok. Normal threads. Righty-tighty, lefty-loosey.
RobbieD
2.9l Mafia
3,593
Georgia
Only a barbarian would drink yak milk from a glass slipper.
A proper heathen drinks it from a mukluk.
CamTheHedgehog
ASE Certified Tech
422
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
I don’t know if the pushrod 4.0s are the same, but on my SOHC 4.0 it is a standard thread. Easy (enough) with the special tool, but it feels like every time I do it, no matter how careful, I bust my knuckles on the alternator or something.
snoranger
Professional money waster
ASE Certified Tech
13,742
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Walksnotruns22
23
Washington
Mazda B4000
Thank you to everyone who is answering.
So as I am understanding, if I am standing in front of the truck looking under the hood from grill side. I need to turn towards driver side (right) to loosen?
ekrampitzjr
1,099
Virginia
No. Turn the wrench toward the passenger's side (counterclockwise as you look at it from the grille side).
Here's the kicker: the Haynes manual for '94–'12 Rangers says that on some earlier models the big nut has a left-hand thread. Since your shroud says right-hand, what I said just above applies.
Just went through the same thing on my '11 Ranger. The big nut was right-hand and I loosened it as described. I also had the two special tools and they made the work a breeze.
Walksnotruns22
23
Washington
Mazda B4000
Ok. Thank you very much.
Mechrick
68
Las Vegas
Easy way to tell is to look at the pulley. If it's smooth and runs off the back side of the belt it's normal (lefty-loosie) thread. If it's grooved and runs off the grooved side of the belt it's reverse (left hand) threaded.
RobbieD
2.9l Mafia
3,593
Georgia
The angle of the fan's blades are also a tell for rotation direction. The blades are angled to pull air through the radiator, not push it.
CamTheHedgehog
ASE Certified Tech
422
Charlotte, NC
Ranger Edge
4.0 SOHC
RobbieD
2.9l Mafia
3,593
Georgia
Although @RobbieD will still insist the 2.9 is better than either.
Absolutely!
Seriously, I currently have trucks with a 2.8, a 2.9 two 4.0s; and a 2.3. (I think I'm just a "wanna be museum")
So what's my favorite?
The 2.3 liter Lima four. o_O
It's like a refreshing break from all of that cologne.
CamTheHedgehog
ASE Certified Tech
422
Charlotte, NC
Ranger Edge
4.0 SOHC
Absolutely!
I see what you did there...
But I honestly do love those lima engines. I learned to drive manual on a Ranger with one, and I somehow didn't stall it once in the process. They may be small, but have more torque than meets the eye. They also don't seem to have any of the "well known" issues that plague the V6s, like cam synchros and timing chains in the SOHC.
