Reverse grinds in M50D
rangerin
North Carolina
2.8
About 1k miles back I put a M50D in my 84 ranger along with a whole new clutch assembly. Since then, it's been working great, with one slight issue. Every now and then reverse will grind as I put it into gear. At first I just chalked it up to my inexperience with driving manual trannies but today I confirmed something is up. I was in the parking lot about to back up into a spot and I tried going in to reverse (clutch disengaged) and the reverse gear grinded some. I tried a 2nd time once I had parked and I was able to repeat it. I'm not sure what's up because both times I was sitting still and the clutch was disengaged. :dunno: Now, I bet I can go a whole week or two before it happens again. Is the tranny or me that's messing up?
bf750
12
Ky
2. Crap
It is what it is
all most all fords grind in reverse .manual trann
96firephoenix
Indianapolis, IN
try putting it in first gear, then keep the clutch in while you move to reverse...
thats how the 5speed in my firebird works, but not the ones in my rangers. :dunno: just a thought.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
Is it hard to get into gear? If you have it in reverse, then take it out and put it back into reverse while holding clutch pedal down does it grind each time? That would mean the clutch is not fully releasing or the pilot bearing is dragging.
Reverse in an M5OD is synchronized, the synchronizer cone is probably just worn out contributing to the crunch. When I rebuilt mine the reverse synchro teeth were almost worn away
rangerin
North Carolina
2.8
I know for a fact that the clutch releases just fine; I can see plenty of travel when it releases. I've never had a hard time getting it into reverse, just sometimes it grinds. Maybe the syncro is a little worn. Before I swapped the tranny I rebuilt the shifter so it's not that either.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
Ok so more likely operator error or a dragging pilot bearing.
Most transmissions don't have synchronized reverse and do just fine.
Try shifting into 2nd before shifting into reverse, that will stop the gear train before the shift into reverse.
scotts90ranger
4,535
Dayton Oregon
2.3 Turbo
My tranny had some wear on the 5/R slider when I rebuilt it, apparently there's two different setups on the 5/R in the M5OD and the switch year is '92, the difference is the tooth count on that synchro set, it's lower after '92 as the earlier ones had the problem you are having more often.
rangerin
North Carolina
2.8
Thanks, I'll give that a shot. It may be me, when I did the trans swap I put in new everything (pilot bearing, throwout bearing, slave cylinder, master, flywheel, etc....) The thing is, it shifts beautifully into all other gears every time. Just every now and then reverse wants to be funky. That being said I've only driven a MT for 1k miles so I'm still new at it.
Didn't know that, thanks! Although, my tranny in from a '96.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Not when synchronized!
Really shouldn't respond when you don't know!!
