Replacing the Rear Passenger Tire
janagyjr
13
Ford Ranger XLT
2.5 (4 Cylinder)
2.5L
15"
I need to take the tire off to take to a tire shop to see if they can plug a leak, where is the best place to position the bottle jack?
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Right under the shock absorber. BE CAREFUL
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,684
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Try to do it in as level of ground as possible and preferably on cement. If on asphalt or gravel, put a board under the jack. The softer the ground, thicker the board should be and the larger a piece it should be. I use 3/4” plywood that is roughly 12”X12” for my jack stands in my gravel driveway. 1/2” thick and the board should be larger than the jack base on asphalt. It doesn’t take much to divot/dent asphalt on a hot day.
And chock the opposite axle wheels.
janagyjr
13
Ford Ranger XLT
2.5 (4 Cylinder)
2.5L
15"
I've got both front tires chocked and a 2x6 underneath the bottle jack (gravel).
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Under the axle tube next to or between the U-bolts is generally the best place for the jack at the rear axle (I think I recall there is also a label under the hood showing the places where to jack it from).
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I just use this guy.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
