recomendations for an intake and tb spacer anyone? headers to
RangerMan9389
Flat Rock Michigan
hello, i have my 08 ranger 4.0l and i'm looking around for a throttle body spacer and complete intake. is anyone running one? what make and how do you like it or can someone recoment one to me. i've been looking at airaid and they make a quick fit kit but i really want the tube to. and afe makes a spacer but i heard airaid was the best. can anyone offer some advice please? and also i would like to run a set of headers as well can anyone recomend some.
thanks
Jeremy
Dweano
Saskatchewan!
I would recommend against the tb spacer. They do little to nothing.
fastpakr
2,850
Roanoke, VA
Both are designed to part you with your money. The factory system is already a much better 'cold air' system than the ridiculous aftermarket kits. They look interesting under the hood and sound different, but that's the end of it.
daniel3507
74
NE Oklahoma
2.3 EcoBoost
the only thing you really get out of a tb spacer and an intake would be noise. i would save your money. hedman headers makes a set for rangers
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
There is actually one thing a TB spacer is good for...
And I regret not grabbing one I saw on a junkyard truck recently...
What is that one thing? it's the perfect thing to drill a hole in to mount a Nitrous fogger nozzle.
AD
RangerMan9389
Flat Rock Michigan
ok well what do you guys think of a set of shorty headers? i found a nice set from JBA.
tony314
Firefighter
12
St.Louis Mo
I had a cold air intake and on my old ranger and they do in fact actually work. I increased my power and mileage a bit. Factory intakes are a good diameter untill it gets to the air filter box,then the inlet hole ( below the filter ) gets really small ( restricted air flow )! Go with K&N.
tony314
Firefighter
12
St.Louis Mo
I'm getting ready to add a cold air intake to my 02 Ranger and duel exhaust.
AllanD
135
1987... sorta
'93 4.0
Cold Air Intakes really do work, which is PROBABLY why Ford designed the truck with one... that you TOOK OFF to replace it with someone else's Cold air intake...
AD
crbnunit
247
Anchorage, Alaska
The JBA's are awesome. The fir and finnish is perfect. You will pay though. They aren't cheap! Stay away from the Paccecrappers. To really make headers work though, you have to go all the way through the intake (heads/valves/cam) and exhaust.
AllanD
135
1987... sorta
'93 4.0
Borla's are also nich, but sadly disontinued...
Not that I'm that sad about it, I've already got mine.
AD
Blueranger99
lebanon, pa
4.0l v6, k&n box filter- this thing sucks... air
if you wanna get more airflow without changing the whole intake, just put a k&n replacement filter in the factory filter box, and cut the front of the filter box out, you know, make the hole bigger. i cut the whole front of the box out on mine, added a k&n box filter, and not only noticed a power gain, but the rumble you get when you jump on the throttle is awesome. it turns heads. my wife says it sounds kinda like a v8 comin up the road.
EERNGER
Michigan
I am running an airaid quick-fit system on my truck.. slightly less lag in the throttle response and more intake noise is what i got from it...i still have yet to figure if any improvements in MPG's have taken place with its addition and my gibson exhaust but i highly doubt it. do the airbox mod from the tech library and a catback, that will give you a bit more noise and thats about all your going to get from those mods any how...only nice thing is the look when you pop the hood...but that only gets you so much and the price kinda sucks :(
AllanD
135
1987... sorta
'93 4.0
Cutting holes in the air box lets HOT engine compartment air into the box...
AD
Ranger#1
5
lake havasu
ad do u think they will ever learn
