rear steer axle
mikej83
Hey guys, search doesn't wanna work, so I'll just ask. Putting full width axles in my B2. Thinking about rear steer. Could this be achieved if I took a Dana 60, cut 2 long tubes/axles from a front 60 to center the pumpkin? any ideas/input would be greatly appreciated:) thanks!
UrbanRedneckKid
17
Cass Co, Missouri
Probably less work to cut a rear 60, and weld on the Cs. At that point I would start looking at Reid Cs and knuckles.
2 PS inner shafts could be cut and resplined, if custom chromoly axles aren't in the budget.
Sent from my HTCONE using Tapatalk
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
That would work, but I gotta ask a question. Where do you live that front 60's are so abundant that you have a few laying around that you can cut up?
SVT
mikej83
Southern British Columbia:) off road community is huge here, plenty of guys converting to rockwells, and I personally know half a dozen farm boys with 3 or 4 old fords and chevs rusting away in their fields with 60's:) not hard to find any Dana for a couple hundred bucks here:)
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Damn, your lucky. I need to send a shipping container your way :icon_thumby:
SVT
mikej83
Hehe, yeah, definitely helps out with the cost of a project. Have gotten most of my parts from buying abandoned project for Pennies. Other stuff can get pricey though. Looking at a pair of steering rockwells for my diesel project, 3500, but comes with disk brakes on all 4 corners and steering setups. Definitely more than im used to paying! But I got totally redone b2 frame coated, a rebuilt Dana 20 tcase, redone c4, and enough parts to full a truck and car trailer for $100 cuz the guy lost interest and was moving.
mikej83
And thanks to both of you for good advice:) agreed welding the C's is probably the easier way to go.
koochman450r
New boston, MI
4cyl
also use a front dana 60 carrier so you can run 35 spline inners if you don't cut up a 60hd rear. All stock front 60's were 35 inners only select rears were. Use chevy or dodge knuckles because they are stronger than the ford front 60 knuckles. Thicker castings.
