Rear Hatch Repair
stimmie78
Uinta Basin, UT
What's the best way to repair the busted fiberglass caused by the spare tire carrier? I plan on building a new rear bumper that would have a new carrier so I want to repair the big hole in my liftgate.
ragajungle
Burlington, WI
2.9L V6
As soon as you find out lemme know, my handle was never there when I got the truck - half tempted to jus goto the u-pull-it n by another rear hatch for $60 instead of screwing around with diamond plate, rivets and explorer handles - for now I jus use a screwdriver
ChopTop84
Carbonado
2.8
Its just fibreglass, if you can do paper mache from elementary school, you can do glass work.
Go to west marine, or any boat/marine supply store, and get yourself some glass mat and some 2 part epoxy, or vinyl ester resin, or whatever they have in stock for cheap.
Get the gate on a flat surface/horizontal.
Grind out the damaged section. Use a 10 to 1 taper. Meaning if the thickness of the repair is 1/4", then you need to grind out about 2.5 inches tapering up.
Hot glue, tape, whatever, a solid piece of wood to the inside of the gate so you have a backing to work against. Put a piece of wax paper on the wood so the resins dont stick to it and glue that wood to your gate hahah.
Cut out pieces of the glass to fill the hole, getting larger and larger until you've built up the hole to the level of the painted surface. Do a little more than you think you need and leave it a little tall.
Now mix up your epoxy/resin. Wet each piece of glass with the resin and lay it in place, and roll/squeegee any air bubbles out. Keep doing each piece of glass until you've filled the repair area. Let dry overnight, sand flat and reinstall hardware and paint.
You can then reinforce the INSIDE of the gate in the high stress areas by just adding more glass and resin and build it up. Dont get too thick tho, as I believe the gate latch can only handle up to a certain thickness.
Sounds hard, but any grade schooler can do it, its alllllllll in the prep work tho.
stimmie78
Uinta Basin, UT
You assume I've done paper mache..... Not a lot of room to taper a lot since it's close to the window. I'll have to see what I can find for repair kits and I guess I'll have to get a grinder of some sort..
ChopTop84
Carbonado
2.8
well, and there lies the problem. If you already have the tools, and most of the supplies, its a cheap easy fix. If not, then your almost the same money or less (after factoring in time) to get a non broken hatch from the wrecking yard, if they are available in your area.
johnsongang
San Antonio
Bronco II
2.9L
Just wondering what you ended up doing? I need to repair mine also, but I want to make it stronger, like with steel/
PetesPonies
25
east coast
2.3l
Fiberglass repairs are nothing to be afraid of at all. Show me a pic of the damage and I'll tell you how to repair it.
