Rear Drive shaft cv joint
natedogg99
Coquitlam BC
2.9 L
When i accelerate hard in 1st or second I have a loud noise I think its the cv joint in the rear drive shaft
I have a 89 bII and i know there are 3 u joints down there
Is there anyways i can service/lube them?
don't really want to bring it to a shop but i can't seem figure it out.
i can only describe the noise as a "clacking"
sorry I know its not a lot of info
thanks guys, any tips would be helpful
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
If its a cardan driveshaft, then you probably need a new carrier bearing. If you have an actual CV shaft, then I suggest upgrading.
natedogg99
Coquitlam BC
2.9 L
How can I tell the difference?
Anyone know what comes on a stock bII?
4.0B2
151
Walls, MS
4.0 v6
most stock b2's are cv joint types
does it have ujoints? or does it look like an oversized front wheel drive car axle?
disciplerocks
53
Evansville, IN
Left is CV (and you can see what they are good for) right is a double cardan.
Junk Collector
Truck of Month
4,862
Rapid City SD
No Bronco II in existence has a carrier bearing on the driveline. Extended cab Rangers do and so do a lot of fullsize pickups but you usually ONLY see them on trucks with two piece drivelines.
Your noise could be related to a lot of things, bad u-joint would be on the top of my list of things to check. Transmission mount and motor mounts are also a possibility, could be slop in the rear axle.
MJSBII
1990
bronco II
What the double cardan out of
old man b2
ebay,, put an aftermarket one in with u joints,costs about 200. but well worth it
