Ratio question!!! Help
ElChP
Costa Rica
2.3
Job 14,1-2
Hola. Tengo un Ford Ranger 1984, 2L, la caja de cambios dice "e77a 7003 afa" y el diferencial es un 373. Mi pregunta es, ¿ese engranaje y la relación diferencial admitirían un motor mitsubishi 4b56? ¿Funcionarían bien? Quiero usar la misma caja de cambios y el mismo diferencial.
Si me puede dar su opinión experta, lo agradezco !!!
Saludos 🇨🇷🇺🇲
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
42
ElChP
Costa Rica
2.3
Job 14,1-2
[QUOTE = "Dirtman, publicación: 1753265, miembro: 101774"]
42
[/CITAR]
42?
ElChP
Costa Rica
2.3
Job 14,1-2
Al leer la estación de guardabosques, creo que mi caja de cambios es una tk5, aunque tiene una placa que dice E77A 7003 AFA, y es 4x2.
ericbphoto
Overlander in development
16,734
Wellford, SC
6"
I don’t know the answer. But according to Google translate, the original question is this.
Hi. I have a 1984 Ford Ranger, 2L, the gearbox says "e77a 7003 afa" and the differential is a 373. My question is, would that gear and differential ratio support a mitsubishi 4b56 engine? Would they work well? I want to use the same gearbox and the same differential.
If you can give me your expert opinion, I appreciate it
ericbphoto
16,734
Wellford, SC
6"
42
[/CITAR]
42?
por favor ignore al Sr. Dirtman. él estaba tratando de ser gracioso.
ElChP
Costa Rica
2.3
Job 14,1-2
Yes Sr.
I want swap my ranger with a 4d56 diésel engine.
But, can I use the same gearbox and the same differential?
Gearbox: E77A 7003 AFA (I think it is tk5)
Differential: 373
Engine: 4d56, 2.5L.
ElChP
Costa Rica
2.3
Job 14,1-2
I mean...
The gearbox / differential ratio would be fine?
Would it support the 2.5L engine?
I say yes!
What do you think?
19Walt93
4,494
Canaan,NH
351
3"
235/55R16
If it's a Tk it should handle it,as long as it isn't abused. If it's a Mitsubishi transmission I would replace it, those broke often enough in unmodified trucks.
3,614
No estoy Seguro que el cambio ve a trabajar con el 4B56. El difirencial no va a tener problems.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
juHwIjDaq ghoS 'ej jImuchlI' Quj neH basement chu' vIvut SoH?
3,614
ericbphoto
16,734
Wellford, SC
6"
I haven't had enough moonshine for this tonight.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Moonshine?
YOU NEED BLOOD WINE!!!!
