Quick Tcase ?
jeepxj2007
Mid-Michigan
I have a 94 ranger with 4.0 al4d and auto tcase, I am about to pick up a BW 1350 manual shift tcase, it came from an 84 ranger, will this work with my truck? and the al4d besides swapping in the linkage?
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
doing the same swap soon, youll also need the drive shaft from the donor truck but other then that should be good to go
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
the only problem you will run into is the front driveshaft will be too long (unless you have the hybrid front axle), you will have to use the driveshaft from the 1350 because the slip joint is in the case not the shaft like with the electric 1354 you have. you would need to shorten it 1" if lifted or 1.5" if stock height
