Capriman86
- Sep 10, 2012
- 0
- Ford
Question for those that have done the airbag light repair....
Passenger Airbag Disable Light Repair (code 27)
If you used the Radio Shack LED called out in the fix, does your LED still illuminate slightly when it is supposed to be off? This photo makes it look like its glowing bright, it is not.
This is with the Airbag set "on" and the bulb replaced with the Radio Shack LED.
It glows full brightness when I first start the truck or switch it to "off".
I am thinking of just getting an incandescent bulb to try instead as I think the LED is just getting a little remaining voltage that a regular bulb wouldn't be able to light with.
