Pulling 4.0 engine
RBereswill
St. Louis, Mo. USA
Ford Ranger 4x4
I have a 2004 4.0 4x4 automatic . I'm pulling the engine. I can't find the top bolts to the bellhousing. Anyone know how I can get to them?
Like
Comment
BlackBII
Ranger Custom
Truck of Month
982
UT
I usually get to those from up top with a flex ratcheting wrench. If you reach your hand down behind the intake manifold you should be able to feel them.
You can also get to them from underneath with a bunch of wobble extensions, but that's usually more difficult.
Monkeyboy
Canada
Long extension from below. Like at the shop.
RBereswill
St. Louis, Mo. USA
Ford Ranger 4x4
Thanks for the help.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
All else fails, cut hole in floor.
RBereswill
St. Louis, Mo. USA
Ford Ranger 4x4
No problem there . I just found that my floor board is rusted through. I gus that will be my next project. If I can get it running again. My first time pulling a engine.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Taking it out is easy. Take your time and keep telling yourself to do it the right way now when it's easy, and not fix it when you put it back together. Much easier to take stuff apart while block is hanging in front of you.
I have mine out for the third time now because I keep ***ing with it. Takes me less than two hours to pull mine because I changed around wiring and plumbing to be as fast as possible.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Oh, and future you will thank present you when you anti seize every single nut and bolt when you put it back together. Trust us on this. Spend the 9 bucks and extra hour. That's all it takes to not fight with shit in the future.
RBereswill
St. Louis, Mo. USA
Ford Ranger 4x4
I have been using anti seize. I been wondering if that stuff works. I'm also using the rust transformer paint.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,701
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Anti seize certainly works. It doesn't take much to make a difference. Especially on spark plugs. There is nothing worse than dealing with a seized or snapped spark plug.
RobbieD
2.9l Mafia
3,524
Georgia
Two seized or snapped spark plugs?
HIGHLY recommend anti seize when reassembling. You'll thank yourself later.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Or 8 of 10 on a 3-valve Triton.
Kira
62
Champlain + Hudson Valleys
Ford Ranger FX4
This Anti-Seize thread started as a bolt location question. lol
I bought nickel anti-seize as it withstands high temperatures.
My 15 year old 4.0 has it's original plugs at 50,000 miles. Would you change them for rust related reasons?
