Proper install order.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Lol you gotta take the boot off, inside the boot is the nut, on the nut is a locking pin. (Like a cotter pin).
You gotta remove the pin then turn the nut not the rod. :icon_thumby:
Fryedbm
41
Ks
So the boot....is that what I am calling the bellow....on the Inner tie rod?
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Yep. Just different name for the same thing.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,819
Wellford, SC
3.0L
6"
Did you loosen the locknut from the adjusting collar?
By the way, some of the threads in these assemblies are left-hand threads.
Go with what Dirtman said.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Here watch this...
Fryedbm
41
Ks
Fryedbm
41
Ks
Fryedbm
41
Ks
Here watch this...
Upper control arm in but not all the way yet.bshould I do lower ball joint first or go ahead and finish upper control arm
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
The upper and lower control arm bolts should not be fully tightened until everything is assembled and you can lower the weight of the truck back down onto them.
Fryedbm
41
Ks
I loosened the lower control arm but when I try to jack it up for new ball joint install the whole truck goes. What am I missing here?
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Nothing, the lower control arm is still on the spring and the spring is on the frame so jacking the lower control arm will lift the vehicle. If the upper control arm is installed put the steering knuckle/spindle on the lower control arm first and then jack it up, the truck will lift some but once the weigh is all on the spring you should be able to pull the upper ball joint right down into the knuckle.
ericbphoto
16,819
Wellford, SC
3.0L
6"
I think he needs to replace lower ball joint first. Truck just isn't jacked up high enough to get the clearance.
Fryedbm
41
Ks
Ok. So I need to go higher. This makes more sense. Lol. Sorry Dirt
