Mike, my phone was destroyed in a keg explosion at work. PM me your number.
Truck runs after massive amounts of problems.
I slowly replaced every bit of the fuel system trying to find the issue.
First it was returning way too much fuel cause the return regulator was fubared.
Second, the pump went out.
Third, fuse blew.
Forth, over pressureized the fuel rails due to issues with problem 1. Cracked an injector and developed a slow leak and the inability to keep fuel pressure.
Fifth, the check valve in the new pump was shot and lettin fuel dump back into the tank through the send.
Now I'm running an oil pressure guage as a fuel pressure guage off the a piller. It's fun to watch it as I drive.
The rear bed mounts are done, the front had/have to be revised due to the gas tank placement.
So now it's just down to:
Having drive shaft balenced (co worker's uncle owns a drive shaft shop. kick ass)
Shock mounts/cross member
Front bed mounts / diamond plating
Tucking up brake lines and fuel lines.
To give a good idea of how shitty the work weather has been:
Oatmealman decided to use an old wheel to help us keep warm while cutting and welding in the snow. To hell with that entire "earth on an axis" thing.
