Powertrain Control Module
rumblecloud
1,136
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Not sure this qualifies as "miscellaneous," but I just pulled it to check on its condition thinking it might be the cause of my most recent issues.
Surprisingly, it looks really good. But your thoughts are welcome...thanks.
I'm going to clean it up a little and replace it
Side note on removal:
The SOBs used a 10mm nut on the top easy-to-get-to nut and a 7/16" on the bottom one that you have to get to by feel mostly (unless you pull the fender liner. I just hole-sawed an access point and will cut a cover for the hole.
holyford86
Some guy with a problem
649
Plattsburgh, NY
many
33x12.50R15
the capacitor on the right hand side looks like it may have failed, seems like there may be corrosion under it, unless my eyes suck more than I think
RobbieD
2.9l Mafia
3,587
Georgia
That right front capacitor doesn't look great. Looks like a leakage stain on the PCB from the rear leg, and maybe green corrosion on the front leg.
rumblecloud
1,136
48022
Ranger Splash
Stock
Yep...both right . I cleaned up with q-tips and alcohol. Here's what I think was the problem all along....
I do not know for sure at this point, but indications are that this was the culprit causing my problems -- fingers crossed.
Nevertheless, no codes. Went slow at first, increased speed slowly. Finally got th nerve to stomp it when I was close to home.
Shocked that it worked.
EDIT: cleaned up the gibberish - must have been really tired.
8,374
Change all 3 blue capacitors, under $5
They are done after 20 years
You need to match the uF, but the voltage(v) rating can be higher on replacement
i.e. 16uF 16v can be replaced with 16uF, 50v, doesn't help or hurt, its just helpful if exact voltage is not available
Capacitors are used to stabilize voltage on a circuit, before complete failure, i.e. leaking or bulging top, they will cause other issues, but never set codes
Yes, that ground point was pretty bad
rumblecloud
1,136
48022
Ranger Splash
Stock
Looks like I need two 16V 47 uf and one 63V 10 uf. I will go ahead and purchase them (quick search found 3-packs through Amazon for around $5 - $6) , but for right now, I am going to enjoy the driving part. Now that I know how to pull it (20 minutes maybe) and what I am dealing with I am not so hesitant about doing it. I'm not really good at soldering, but capable enough to do this.
I still want to shakedown the truck to convince me that the problem is solved -- and give the wife something else to talk about ---wait di I just say that out loud?
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
View attachment 83659 View attachment 83660
This is the info with regards to the proper Caps I was looking for.
Two 16V 47 uf and One 63V 10 uf
Is yours a 93 4.0L Automatic ?
8,374
Google: electronic component shops
Should be under $5 for the 3 you need in 105deg Black, even when buying 5 packs
They cost 30 to 50cents each, i.e. $1.50 for 5
As said, if cap has 16v(volt) rating you can use 25v, 35v, 50v, 63v ect..........and it works the same
But uF has to match exactly
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
I got 10 - 47uF and 10- 10uF on eBay. The total cost was under $3.00 for twenty pieces.
That's the only way they sell them 10 pieces. So I will have extras for anyone if needed, for free, I will pay it forward.
