Power Window Motor Repair
mrecoolgar
Hershey PA
There are other posts regarding this problem including a nice write up.
Thanks to these post I repaired my 1990 Ranger.
The Help #74410 states for "various Ford models 2003-1965".
The window regulator gear plugs are nylon and measure 1/2" diameter by 7/16" length.
In short, these plugs break down into small chunks leaving the motor still working but unable to move the glass.
Hope this helps.
Coyotebyte
So Cal
2.9L V6
I havent really found aything that shows me a pic of how to remove the motor. I have these pieces but cant get to the bolt on the motor for my 89 B2. Can you direct me to any of these posts?
RANGERROD
November 2012 OTOTM Winner
st helens or
I just drilled holes through the door to access the bolts for the motor. It will be covered with a door panel anyways. Thanks for the part number on the rebuild kit.
fangotango306
8
sc michigan
None yet
i just did this mod but i actually drilled three holes in the plastic gears and put screws through with nuts on the inside and ground the screw heads down a little, worked like a charm.
fangotango306
8
sc michigan
None yet
and holy old thread
alwaysFlOoReD
5,174
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
SCOTTY
121
Above the equator
Ford Ranger XLT
Cologne 2.9 V6
My '90 Ranger has Bosch motors still goin strong & they're different than the others with the bolts for the gear assembly.
It has a bunch of friction fit pins ?
