RWB65
- Jun 21, 2021
- 0
- Victoria TX
- Ford Ranger
Hello, I’ve gat a 97 2wd ext cab 2.3 Lima 5spd. Taking off from a stop, I have no power. I have to rev the motor to about 3000 to go. The motor has 188000 miles. Passes emissions with great numbers. I have replaced plugs, wires, coils, MAF, tps, temp sensor, ecm.
Timing Belt. Also replace fuel pump, filter. When engine is cool, the problem is not bad. When hot, it gets worse, when I turn on AC, really bad! Over the winter the temps were cool. Seemed to be ok. Tried coming thru Houston rush hour last week. A couple of times I didn’t think i could get it to roll
i hung a timing lite on it for fun. (I know timing is not adjustable.) idle is 10 btc crack the throttle open it goes 7 ATC, and doesn’t recover for awhile. At 3000 I’ve only got 16-18 BTC (no wonder i cant take off!!) any ideas what else i can try. I appreciate any help. 40 years as a tech, I’m lost on this one!
