Possible transmission problems?
warmachine5500
Tras problems? Ranger seems to be misfiring in high gear
The problem vehicle is a 94 Ranger 4.0 4WD. It has about 114K on it. I owned this truck for about 7 years, and never experienced this issue. My uncle owns the truck now as his backup vehicle. He's old and retired, so he doesn't travel far. Or fast for that matter. Yesterday my brother had to borrow the Ranger, as his Blazer is in the shop. He has a about a half hour - 45 minute highway drive to work. It's mostly uphill since the highway travels up a mountain. He reported to me that the truck started shaking while on the highway at around 65 mph.
I looked underneath the front end tonight and everything seems in place. I took it for a drive and I could not replicate the shaking. Even on the highway at 65-75 mph it didn't shake, so I ruled out unbalanced tires. Then I took his route up the mountain. The truck seems to stutter while it's in its highest gear, around 1800-2000 RPM, about 65-70 mph, but ONLY when going up a fairly steep consistent grade. If I give it more gas to make it downshift and bump it up to 3000 or more RPMs, the shaking goes away. The shaking feels like a cylinder is misfiring, but it would do that all the time if that were the case. Not to mention, I have no check engine light at all.
Is this the transmission slipping? 4th gear going out? Any help is much appreciated!
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Manual or Automatic? I am going to assume that is it an auto. When you think the transmission is slipping do the RPM's climb. But then you say when going up the hill it acts like it is misfiring. When was the last time it was tuned up? Sounds to me like it is misfiring under a load.
warmachine5500
Automatic. No the RPM's don't climb when it feels like it's slipping. It just stays in 4th gear and chugs/shakes right around the speed/RPM's I mentioned. But only when climbing a hill. I'm not sure when it was last tuned up. I'll pull the plugs and give them a look when I get a chance.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Definately sounds like it needs a tune up.
If the transmission is slipping the RPM's will climb while it is slipping.
warmachine5500
I dumped a bottle of Lucas in the tranny the night that I test drove it. My brother spoke to me today and said it wasn't acting up anymore. I'll check those plugs anyway when I get a chance.
warmachine5500
So this problem kept getting worse. It was beginning to act up in 3rd gear as well, and the bucking got really really bad in 4th. I changed the coil, plug wires, and spark plugs. One of the plugs (number 6 I think - the one nearest the heater core) porcelain was broken near the bottom of the electrode. After changing these the truck does run better, but still feels like it is misfiring in 4th gear. It's not as bad now, but still very noticable. I still don't have any check engine lights. Any more ideas? Fuel filter? Injectors? I'm stumped. Thanks.
swynx
9
lewiston idaho
Mazda
i would change the fuel filter, had this happen alot because of fuel filter.
warmachine5500
Thanks. I will change the fuel filter and report back with my results.
warmachine5500
Installed a new fuel filter and the problem still persists. It idles better than it ever has, and it runs great around town/low speed. But it still seems to misfire in 4th gear. This is really bugging me!
