Possible frame swap?
Trucker1159
6
Columbus nebraska
Ford ranger
Has anyone resto modded s ranger???
I'm not quite sure if it's a fesable idea or not. But has anyone tried mounting a early-late 80s body on a 98+ ranger frame?
rusty ol ranger
2.9 Mafia-Don
7,554
Michigan
177 CID
Im sure it could be done with creative mount placements.
racsan
4,464
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
cant be any worse then the car 4x conversions like a mustang II on a bronco chassis or a caddilac hearse on a suburban frame.
sgtsandman
Aircraft Fuel Tank Diver
12,663
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
With enough time and money anything can be done.
The front frame on the pre-1998 trucks is different. So there will be fabrication work. The aft frame is the same. So a bed swap shouldn’t be a problem.
snoranger
Professional money waster
ASE Certified Tech
13,663
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Regular or supercab?
A supercab should have pretty much the same wheelbase. A 98+ regular cab will be 3” longer.
I don’t think you’ll like the look of a 3” gap between the cab and bed, and if you line the bed/cab gap up the wheel wells won’t look right.
Ramcharger90
1,708
N/A na
306, Bcam,
Im not sure why you want to. Again yes any thing is possible. My friend builds hotrods for a living. But I would think its more cost effective to build a whole new chassis and make that truck move and corner.
Trucker1159
6
Columbus nebraska
Ford ranger
I would rather use a pre existing frame with readily available parts... And I'm trying to do away with the headache of twin i-beams.( I deal with it on my DD regularly)
rusty ol ranger
2.9 Mafia-Don
7,554
Michigan
177 CID
What exactly is causing you headache with the I beams?
They are comperable to normal IFS in alotta ways and superior in quite a few ways.
Ramcharger90
1,708
N/A na
306, Bcam,
I have a feeling the I beam is bent from the previous owner like one of mine were on the 90 or he needs shocks and bushings.
rusty ol ranger
2.9 Mafia-Don
7,554
Michigan
177 CID
Id think it would be eaiser to replace the beam then cobble a old body on a newer frame.
How the hell do you bend an I beam?
Ramcharger90
1,708
N/A na
306, Bcam,
Accident, or something low and stationary like a big rock.
don4331
1,346
Calgary, AB
5.3
There are a bunch of things on 30 year old truck that add up - parts wear and replacements get hard to find/expensive - e.g. brakes/camber/caster adjusters wear on knuckles, necessitating replacement. There are some advantages to the "disposable" components on newer trucks - replacements are easier to come by.
Basically, you're doing the opposite of this:
https://www.therangerstation.com/tech/putting-a-1998-ford-ranger-cab-on-a-1993-1997-ford-ranger-frame/
If a regular cab, you would want to shorten the frame 3". Not that big of a deal if you are considering the frame swap in the 1st place. (Drill out the 16 rivets, slide the frame sections together 3" more, bolt up with grade 8 fasteners; use your existing driveshaft - it is 3" shorter).
For a 2wd, especially, if you want to lower, ifs probably beats tib. Lifted and/or 4wd, I'd probably lean towards ttb
One thing to remember - '93+ Rangers are 2" wider - not a lot, but it does push the wheels out - you may/may not like that look. Alternatively, if you are running say Mustang rims, you can run them without spacers and track would be very close to stock.
Ramcharger90
1,708
N/A na
306, Bcam,
I wish this guy had more details on his build I want to build a similar setup. Like dimensions and exact measurements. Maybe he does and I missed it. But I would like to copy his work with maybe some different things.
Trucker1159
6
Columbus nebraska
Ford ranger
I've got access to a 01 that crushed by a tree essentially I wanna take just the frame and front suspension put a 302,5-speed and a 9 inch out back and the drop it to about a 3-4 inch ride height
