PCV Valve Location
BCWW
Arkansas
2.3 liter
Sorry for the dumb question, but where is the PCV valve located on my 2005 2.3l. I have look in the obvious places and the not so obvious and am at my wits end.
Thanks
Bryan
trioxin1308
PCV location
Brian,
This drove me nuts too. You'll find it on the bottom half of the right side of the engine as you stand in front of the truck facing it. It helps to remove the soft rubber splash guard inside the tire well. Getting at it from inside the fenderwell was the easiest for me, and I found taking the tire off was the best way about it. If you follow the hose from the back of the intake going down, you'll find it.
T.
jax4bangin
WESTMINSTER CA
2.3
what is the purpose of the PCV? what job does it do?
dorman68
2.3L
The pcv valve is on the side of the engine with the intake manifold. You have to look real hard behind the intake manifold, the pcv valve sits in crankcase vent oil separator box on the side of the engine block. Here are intructions from Alldata, not to clear but hope it helps.
POSITIVE CRANKCASE VENTILATION (PCV) VALVE
Removal and Installation
Remove the left front inner fenderwell splash shield.
Disconnect the coolant bypass hose from the routing clip.
Gently pry the positive crankcase ventilation (PCV) valve cap off the two tabs.
Remove the PCV valve from the crankcase vent oil separator and disconnect the vacuum hose.
To install, reverse the removal procedure.
Wicked_Sludge
43
Westport, WA
3-point-GO
PCV stands for Positive Crankcase Ventalation. as the name implies, it forcefully ventilates the crank case using the engines vacuum to pull air through the crankcase, thus preventing the buildup of fumes (even healthy engines have a minimal amount of blowby) inside the crankcase. its good for your oil, its good for your fuel economy, and its good for the environment.
BCWW
Arkansas
2.3 liter
I finally found it and got it changed. What a screwed up location. Thanks for the help.
Bryan
nederanger
2.3 L
PCV valve cap removal
I've got the splash guard and wheel off and have located the PCV valve, but now I'm stuck. I see 1 horizontal slit about 1/4 inch long on each side of the cap and I can rotate the cap a little, but how do you pry the cap off? With a screwdriver? and what to pry against?
A little help please.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
Bryan
it's in a bad spot in my 4.0L SOHC too, the BACK of the block, cant even hardly get to it.
