PCM Part Replacement
megnarium
Alberta, Canada
Mazda B4000
Hi all
I have a 1998 Mazda b4000 truck. it is as basic as you can get. crank windows, no abs, automatic, rear wheel drive, v6.
the mechanic thinks we need a new PCM and his research showed there was only one in Canada that would fit the truck (used $800; which he says is a ridiculous price). I've been trying to get additional information from him for the last two weeks but he's busy or something. (honestly not sure why he never called back, technically I'm still waiting). So I've been trying to find a PCM myself. I've found articles saying the original part number is ZZT418881A (i have no idea if this is accurate), I've found other articles talking about supersessions and gotten some additional numbers. Currently I'm *almost* sure the alternate numbers listed from this website would work (https://mintt.com/mazda-pcm/b4000-engine-control-module/1998-mazda-b4000-pcm-ecm-ecu-programmed/) the alternate part numbers listed on the website are all variations of this code: 'F87F-12A650-AGA'. Today we pulled the pcm unit out of the truck itself and it looks (to me) like its already an aftermarket unit and it has the following number F87B-14B205-DD. So help me out. what part do we buy??
The F87B-14B205-DD number seems to only be available as a used refurbished unit from ebay sellers and I would much prefer a clean programmed one from the Mintt website (or one similar).
Any thoughts would be appreciated
franklin2
1,769
Virginia
Here are the choices for a 1998 B4000 pickup that www.car-part.com gives.
1998 Mazda Pickup-B4000
Engine Computer
Electronic Control Module, (RH rear firewall), ID F87F-AGA
Electronic Control Module, (RH rear firewall), ID F87F-AGB
Electronic Control Module, (RH rear firewall), ID F87F-AHA
Electronic Control Module, (RH rear firewall), ID F87F-AJA
Electronic Control Module, (RH rear firewall), ID F87F-AKA
Electronic Control Module, (RH rear firewall), ID F87F-ALA
Electronic Control Module, (RH rear firewall), ID F87F-ALB
Electronic Control Module, (RH rear firewall), ID F87F-ALC
Electronic Control Module, (RH rear firewall), ID F87F-AMA
Electronic Control Module, (RH rear firewall), ID F87F-ANA
Electronic Control Module, (RH rear firewall), ID F87F-ANB
Electronic Control Module, (RH rear firewall), ID F87F-ANC
Electronic Control Module, (RH rear firewall), ID F87F-APA
Electronic Control Module, (RH rear firewall), ID F87F-APC
Electronic Control Module, (RH rear firewall), ID F87F-AGC
Electronic Control Module, (RH rear firewall), ID F87F-AHB
Electronic Control Module, (RH rear firewall), ID F87F-AHC
Electronic Control Module, (RH rear firewall), ID F87F-AJC
Electronic Control Module, (RH rear firewall), ID F87F-AKC
Electronic Control Module, (RH rear firewall), ID F87F-AMC
Electronic Control Module, (RH rear firewall), ID F87F-BTA
Electronic Control Module, (RH rear firewall), ID F87F-BUA
Electronic Control Module, (RH rear firewall), ID F87F-BVA
Electronic Control Module, (RH rear firewall), ID F87F-BXA
megnarium
Alberta, Canada
Mazda B4000
Engine Computer
Thanks for the reply. How do I know if any of those would work? I don't intend to sound like I'm complaining and I'm not that knowledgeable about vehicles. What is the RH rear firewall? The listed ID's are missing the middle sequence from my post that is some variation of: '14B205' or '12A650'. Based on the listed numbers the part from website I listed in my original post should fit. Can you help me out with any additional details and what the different number sequences mean? Thanks
8,372
You want a Ford replacement computer(PCM)
Ford uses Part numbers up to 1998 like this
F8 = 1998, F7=1997, F0= 1990
7 = Ranger, or Mazda B-series
F = Department in charge, in this case Electronics Dept
Center number on all Ford PCMs is 12A650 still used today, meaningless as far as looking for replacement, which is why most websites don't include it
You just get the first 4 and then the last 2 or 3
Like F87F-ABC
Last 2 or 3 numbers in this case is the Software/Firmware revision, Ford NEVER released a cross reference for this
The ONLY thing you really need to match is 4.0l engine and automatic transmission on a 1998 Mazda B-series or Ford Ranger
I assume it has an EGR system and a Cam sensor, I think all 1995 and up 4.0ls did
PCM doesn't care about power windows, 2WD or 4x4, trim packages, just engine size and transmission type
As said above try car-part.com
1998
Mazda B4000
"Part" Computer box engine
Your Postal code
Search
The select first one on the list F87F-AGA
Search
Also do the same but use 1998 Ford Ranger probably cost less since there will be way more of them
You want one from an Automatic(AT), not manual(MT)
Usually wrecking yards are 1/2 the price of new/rebuilt, so if new is $200 then its $100 or less
Computer's RARELY fail, so used is a very safe bet
You can't use a 1999 computer(different cam sensor) or a 1997(4R55E trans software maybe)
RH Firewall is the location of the Computer, its located at top of firewall towards the passenger side(RH, right hand)
megnarium
Alberta, Canada
Mazda B4000
Like F87F-ABC
1998
Mazda B4000
Your Postal code
Search
Search
Wow, thank you so much for the information, I followed all of that. haha.
Off to continue the search!
megnarium
Alberta, Canada
Mazda B4000
Like F87F-ABC
1998
Mazda B4000
Your Postal code
Search
Search
Thank you again for the information. I came up with another question. The places selling new/rebuilt all say they flash them to our trucks VIN. How does that figure into one from the auto wrecker?
franklin2
1,769
Virginia
You may have to take it to the dealer to get it flashed if your truck has the security system on it that wont let it start. They had different versions of all that, I am not up on what year and model has what security system on it.
8,372
Your VIN tells the re-seller the Emissions Level, Federal or Calif.(CARB), Engine Model(4.0l OHV) also Manual or Automatic transmission
And that's it
You can get that by just looking at a Ranger/Mazda in wrecking yard
4.0l engine
Manual or automatic trans
Fed. or CARB emissions had more to do with the Cat Converters in 1998, as most engines had to have EGR systems by that time, so not really an issue either way, and not likely to find a Ranger/Mazda from Calif. in a Canadian wrecking yard :)
