Pauls 1998 ranger 4x4
Paul hall 7999
va.
Ford ranger
Need help I put a 1994 ranger 4.0 ohv motor in my 1998 ranger witch also had a 4.0 ohv in it I took the 94 Intake amd heads off and put all my 98 stuff on there and i noticed the 94 had no camshaft synchronizer in it so I took that out and out my 98 knee in it. Well it was to long so i cut about a quarter inch off and it fit. Well make a long story short it runs I've been driving it for awhile now and it doesnt not run right lean codes rich codes any help would b great
8,370
Welcome to TRS :)
If you have lean AND rich codes then you probably reversed the upstream O2 sensor plug-ins, had a shop do that once when they replaced the clutch, lol
O2 plugs are universal so one size fits all
Look at/find the passenger side O2 wire and follow it up to where it plugs into the Trucks wiring harness
Should have these 4 wire colors
orange
grey/blue
blue/orange
red/white
If you see a red/black or yellow/blue then they are reversed
Yes, you can used the 1998 cam synchro on the 1994 engine, not sure what you "cut off" but you shouldn't have to do any cutting
The 1994 4.0l Rangers did use Cam synchros/sensors if sold in California, so should have just fit, these do need to be timed, just like a distributor needed to be timed
Paul hall 7999
va.
Ford ranger
Welcome to TRS :)
orange
grey/blue
blue/orange
red/white
Well the 94 had the camshaft synchronizer but it was only a flat plate with the oil pump gear under it no sensor wires nothing and I'm in virgina and I did have to time it and it took me a lil bit cause I had never messed with the camshaft synchronizer before and what I cut off was about a 1/4" of the bottom of the camshaft synchronizer it was to long I held them both side by side I still have them.
Paul hall 7999
va.
Ford ranger
Now I did this swap like 2 years ago I dont drive the truck very much cause it only gets like 180 miles to a tank of gas but it's been screwd up to long and I love the truck and want to drive it more and the only reason I went the rout I did is because I didnt have the money for a new motor and a friend had the 94 and it was totalled and only had 50.000 miles on the motor. And I'm not sayin ur wrong but I've been threw this truck so many times I dought the o2 sensors r backwards but I will look into it thanks I'll check back with yall n a bit on my way home from work.
8,370
Its called the oil pump drive not a synchronizer if there is no tower and vane
What are the exact codes?
Paul hall 7999
va.
Ford ranger
Yes ur right I had a brain fart I couldnt think I was typing so fast but yea the 94 only had the oil pump drive no synchronizer
