- Aug 6, 2007
- 1,734
- Macon/Fort Valley, GA
- Ford
- Engine Type
- V8
- 2WD / 4WD
- 4WD
Some of y'all may recall reading my post a few months ago about the POS 4.0L in my 99 Ranger that kept blowing head gaskets. Truck ran good except for that. Don't want to rehash the story, but got a used replacement engine from a donor truck and truck seems to be running good again for the most part except for this recurring trouble code.
P1309 = Misfire Hardware Monitor - CMP Misaligned, CKP/CMP Noise, PCM AICE Chip
Also showing the following as pending:
P0133 = O2 Circuit Slow Response (Bank 1, Sensor 1)
P1131 = Lack Of HO2S11 Switches - Sensor Indicates Lean
Not worried about the latter pending codes at the moment just wanted to mention that they are there as well. They could even be related to the cause of the first stored code.
When we installed this engine in the truck, we just installed it complete from the donor vehicle. Can't comment on codes and stuff in the donor truck because there wasn't a battery in it when we went to check it out. We did put in a battery and hear it run and it sounded good, but being a wreck we couldn't drive it enough to trigger any codes. The engine we pulled out of the truck was not throwing any codes like this so, I swapped over the known good Camshaft Position Sensor and Crank Shaft Position sensors from it and reset the computer. Next time I drove the truck the code came back.
I'm figuring the next logical step is to pull the upper intake and replace the Camshaft Synchronizer. I could be really cheap and install the one from my old engine, but its got at least 230k miles on it. I'd also need to buy an alignment too kit for about $20 to get it positioned right. I'm seeing synchronizer, sensor, and alignment tool kits for sale through RockAuto for $30 - $50 made by World Power Systems, Spectra, and Standard Motor Products. At that price it kinda makes sense to just go all new if these aftermarket units are any good. Otherwise, I'll be buying the alignment tool kit and installing the one from the old engine, cause I'm not going to drop near $200 on a just a synchronizer without trying the old one first.
If Camshaft Synchronizer doesn't fix it, the next likely culprit seems to be the PCM and that is a nightmare I really don't want to deal with.
So what ya think, is there something else simple I could be missing that would cause this? Are the aftermarket camshaft synchronizers any good?
