Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
if you’re looking for the manual transmission end yoke, which is exactly my situation that i had, got one from a 3.0 2000 extended cab AUTO, you need part #F6ZZ-4841-BA it is the correct yoke for the manual trans with the weird weight thing on it, i tried using the original slip yoke from my 96 manual and realized they are different size u joints.I was browsing through old threads and figured I'd add a little info here for the sake of completeness and to benefit the next guy who might want the same info (and knows how to use the search function).
To add to what Allan back in December, Here's a pic of the end of the drive shaft slip yoke from a 2000 Ranger/2wd/3.0L 4R44E automatic. It appears to be a 24 spline (or would that be 25?)
or get one from a mustangif you’re looking for the manual transmission end yoke, which is exactly my situation that i had, got one from a 3.0 2000 extended cab AUTO, you need part #F6ZZ-4841-BA it is the correct yoke for the manual trans with the weird weight thing on it, i tried using the original slip yoke from my 96 manual and realized they are different size u joints.
