OK here we go again!
groovtubin
29
NC
Ford Bronco II
Went out to crank the Bronco II Key over, FUEL PUMP PRIME ...NO start...... Its cold, i dont have a garage, soon as it warms up, il TS the Ignition again, this XACT same thing happened over late summer, n i repaired a broke coil wire to Ignition module, what will it be this time? :) In last post i was ALMOST home it sputtered n went into limp mode..
groovtubin
29
NC
Ford Bronco II
OK Braved the harsh elements of nature, pulled off the IGN Module connector, SLAMMED that puppy home, Key over FUEL PUMP PRIME WE HAVE IGNITION! :)
groovtubin
29
NC
Ford Bronco II
OK, NO time to get into it heavy today ( no im not on a date) All i had time today to do was pull back carpet slightly and the WHITE BUTTON on INERTIA switch actually CLICKED when i pushed down, i hvnt checked for 12 volts at fuel relay, B4 this either.... Ive got RUN n COIL voltage at TPI connector, didnt get to CRANK voltage Also the OHMS is GOOD on COIL, i PULLED the secondary wire tab... used a test light, it LIT up cranking....., but couldnt tell if it was FLASHING...( pulled secondary tab OFF the coil n read that directly, maybe wrong?) anyhoo, ill try n crank tomorrow, gotta fuel press gauge for troubleshooting on way, did i say how MUCH i miss driving the Bronco II ?? Its my main ride man! :)
groovtubin
29
NC
Ford Bronco II
Installed SPARE TFI Module ( it wil miss @ 2500 RPM) but does ....................START............ Going to FordMOCO n get the REAL thing, Car parts n Advanced Zone are worthless...for TPI's imho.......................YMMV.............
groovtubin
29
NC
Ford Bronco II
FINALLY got warm weather n stuffed the MOTORCRAFT TFI module in HOLY SMOKES! It really feels like i gain 100 HP, it JUMPS N TAKES OFF NOW like a bulldog in heat!! $168.00 set back but WELL worth it. IT LOOKS to be a Delphi which is ruffly $20 less B4 taxes on evilbay, NO motorcraft insignia BUT they did throw it in a Motorcraft box, how lovely, FWIW IT ROCKS NOW! :) HIGHLY recommended over the AutoZone Oreilley, and Advance CHEAP counterpart..
