Oil pump gasket?
heisler0
Brunswick, MD
I have a gasket for pick up tube but not for pump to block does anyone know if this motor gets a gasket there?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Yes it does, otherwise you would lose pressure.
8,372
Not sure if factory used them, some people make their own
Oil pumps provide way more oil than an engine can use, thats where oil pressure comes from, its back pressure, the pressure of the oil the engine can't use at that time
And any leaking oil at the pump/block surfaces just drips into the pan
The seal/gasket for the pick up tube is so pump doesn't suck in air
heisler0
Brunswick, MD
I don't remember one being there when I removed the pumped but I noticed that some pumps come with them and some don't.
AndyB.
142
Cincinnati, OH
There is no gasket. The aluminum pump body crushed slightly when tightened down and makes the seal.
heisler0
Brunswick, MD
I feel like it would be better to make one and have one there but is there any advantages or disadvantages in doing this?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I've never installed a pump without a gasket. I've definitely had to make my own several times but still think it's one of those things that doesn't really make sense not to use. Its literally like 2 cents worth of gasket paper and most ford engines aren't exactly great for oiling to begin with.:dunno:
heisler0
Brunswick, MD
Thanks everyone for the help! Gasket it is.
Junk Collector
Truck of Month
4,849
Rapid City SD
I think I had to make one when I put my 2.3 together. Couldn't find a new one and the original was like a thin little sheet of paper, not like typical gasket material. 5 years later, it's working great although both the pump and the block are cast iron, not aluminum like Andy said.
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
I have some gasket books from Fel-Pro and Mahle that almost resemble a McMaster-Carr catalogs and no luck there or anywhere else. No kit sold for this engine seems to have one. I just made one.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Its pretty easy to just press the pump onto some paper to make an outline and cut out the shape with a exacto.
AndyB.
142
Cincinnati, OH
The factory Ford oil pump has an aluminum body. When I rebuilt my 2.8, there was no gasket. Parts books, service manuals, no listing or illustration of a gasket anywhere. Not even a trace of sealant on the old pump.
In my rebuild I used a NOS D4ZZ-6600-A, aluminum body.
AndyB.
142
Cincinnati, OH
Base of original pump, NOS pump and pickup tube installed, base of Ford remanufactured Pump I didn’t use—all aluminum. No gaskets for any of these where they meet the block.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I'm not questioning whether or not ford put them on at the factory or if they existed. I've seen some engines with them, some without. My point was just... why not? :dunno: You can't hurt anything by using one and its such a cheap simple thing.
