Oil gauge- real or idiot light?
Chapap
672
NW Florida
Ford Ranger XLT
2.3
1.5” till I get these springs replaced
225-70-R14
Does the oil pressure gauge actually show pressure or is it just a yes/no/idiot light type thing? If it is just an idiot light, would a replacement press sensor make it an actual gauge?
Roert42
4,977
Kintersville, PA
Ranger XLT
4.0 SOHC
I believe you may need to remove or add a resistor into the cluster. To make a real sensor work.
fastpakr
2,834
Roanoke, VA
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
Perfect! Thanks!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
You can do the conversion listed above, you change the sender to a sensor and add resistors or whatnot to the circuit to make the factory gauge work more like a real gauge. But to be honest, if you really care that much I would install a separate aftermarket guage. Not complicated at all and would show actual pressure numbers, the factory guage is still just low and high so no real idea what the true pressure is.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I concur with lawyer-goats client.
A 22$ oil pressure & water temp guage setup from summit would take about as much time to install as the conversion would take.. mabey even less time.. and give you much better information.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
I really don’t want accessory gauges hanging around the cab, but a little digital readout stuck on the gauge cluster would be nice. That’d be nice for temp and voltage as well. I think that’s the plan for the moment.
