Oil Filters
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
Engine Masters season 6, episode 5 did comparison tests on filters.
Junk Collector
Truck of Month
4,800
Rapid City SD
I use Motorcraft filters most of the time on vehicles I care about. I figure any issues will be worked out quick, they sell a lot of them. Usually Super Tech filters on the wife's Prius.
I have a stash of old/cheap filters for junk I don't care about. I scored a case of ancient Conoco filters at an estate sale that are the FL-1A style - they have some random rust spots so they are perfect for a 2.9 truck with 300k on it that leaks everwhere and has holes rusted through every panel. Same with the case of 25 cent Frams I got on clearance at Tractor Supply. A filter is a filter is a filter on that application.
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
Thank you-all for the info. The store in question has their own brand. They're not bad...no crossover chart to check which of theirs subs for all the popular brands. Need an alternate vehicle that uses Ranger filters.....if available.
Any year Taurus that uses the pushrod 3.0 (vin U)
1990RangerinSK
1,312
Saskatchewan, Canada
Is there a Ford (or any) vehicle whose oil filter is interchangeable with a 2002, 3.0L, Ranger...? Store had no filter book only the digital video game look-up box. Showed all trucks, all years, no Rangers. Will anything else fit...? It's a convenient store as I live in the boonies. Thanx
Motorcraft FL-400S
According to this link: Filter for 2002 Taurus w/Vulcan V-6 | Bob Is The Oil Guy (scroll down to post #5), Ford Taurus (as noted by Holyford86) uses the same filter as your Ranger.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Just watched a Filter cut up video on youtube. He cut open 3 frams, a Mobile-1, a Super-tech, and a K&N. 2 of the Frams were Identical ( Orange can of Death, and the Silver Can ) the Ultra High Mileage Fram had thicker pleats than any other and the material was differnet. Looked more like a 'pink foam' while the others were the typical material. The K&N and the Super-Tech were identical, minus the little "nut" on the K&N. The K&N had the stiffest canister, the rest were flimsy when squeezed.
4x4prepper
216
Atlanta
2002 Ford Mustang 3.8L
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
2007~???? Ford Edge or Lincoln MKX V6~3.5L~DOHC
uses same or crossref'd OilFilter as a 2002 Ranger V6~3.0L
FordMotorCraft# fL400s
jeedee
4
OK
jeedee
4
Lots of good info here....I thank all for the replies.
