Oil Filters
jeedee
4
Is there a Ford (or any) vehicle whose oil filter is interchangeable with a 2002, 3.0L, Ranger...? Store had no filter book only the digital video game look-up box. Showed all trucks, all years, no Rangers. Will anything else fit...? It's a convenient store as I live in the boonies. Thanx
ekrampitzjr
1,092
Virginia
Motorcraft FL-400S
Hastings/Baldwin LF134
Fram xx3600 (xx = different Fram filter versions, such as TG for Tough Guard)
NAPA x1516 (x = different NAPA filter versions, such as 1516, 21516, or 41516) (WIX similar)
This should get you started.
A lot of those "video game"–type lookups list trucks separately from cars, such as "Ford" and "Ford Trucks". When looking up models by name, there might be more than one screen to look, and "Ranger" could be on a second screen. Look for a forward-arrow that indicates there's another screen following.
Hope this helps.
19Walt93
4,498
Canaan,NH
351
3"
235/55R16
I use Motorcraft almost exclusively. Purolator and Wix(including filters branded Napa, Carquest and others) are OK, Fram is junk, the ones Jiffy Lube uses are junk, Lee is junk. I use Motorcraft FL910's on my John Deere and Husqvarna lawn tractors. The dealer still sells to me at employee prices and Walmart is often cheaper. K&N probably makes a good filter but they cost more and I have oil filter wrenches so I don't need their hex nut gimmick.
lil_Blue_Ford
6,229
Butler, PA, USSA
4.9L
Anymore I stick to Motorcraft for mine, but I’ll do WIX, Mobile1, K&N if I have to. I will never buy another Fram after what happened with the GF’s car and my buddy’s van. Both had the same thing happen. Buddy’s van was changed at Jiffy Lube with a regular Fram, I did the GF’s car with a Tough Guard because I couldn’t find the usual AC Delco. Filter actually crushed down enough that oil was bypassing the filter some and clogging up things. Buddy’s van did the same thing. Was almost impossible to dig out of both. Never had that happen with another filter
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
...K&N probably makes a good filter but they cost more and I have oil filter wrenches so I don't need their hex nut gimmick.
Have a variety of FilterWrenches here too & yes K&N definitely costs more,
though quality is very good with a nice stout casing & easy access in tight spaces;
I've just had too many others get stuck on, wasted too many hours cutting them off; not an issue with K&N# HP series filters.
superj
2,706
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
I sent those pics to my kids and my oldest son said he just put a fram on his wife's car. He said he is going to get a different brand from now on
jeedee
4
Thank you-all for the info. The store in question has their own brand. They're not bad...no crossover chart to check which of theirs subs for all the popular brands. Need an alternate vehicle that uses Ranger filters.....if available.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Sounds like WalMart?
I'd avoid SuperTech OilFilters as they don't publish their specs (flow gpm & bypass psi ratings); what are they hiding?
Though SuperTech Oil+Lube products seem to be quite comparable to other premium brands & better prices.
lil_Blue_Ford
6,229
Butler, PA, USSA
4.9L
Yup, surprised me when I unscrewed the cap to pull the filter and oil gushed out and the filter didn’t come with the cap like usual. Had to get pliers and a screwdriver and dig it out. Never again. Also guess I should note that the Fram was made in China (both of them, my buddy checked his after I told him) and the AC Delco (stamped GM logo on it too, her car is a Malibu) was made in USA.
ekrampitzjr
1,092
Virginia
Posters on the "Bob Is the Oil Guy" forums have said that Motorcraft, Mobil1, and K&N filters have recently had quality problems and are made cheaper than they used to be. Some K&N filters are reported to leak around the hex nut weld. We're not talking about one or two guys griping, but a lot of members there.
I gave the different filter numbers to give you something that could cross to whatever filters are stocked. You could look at Amsoil too. The Amsoil filter I use on my 4.0 seems pretty well made.
Bill
898
Sacramento, CA
I mainly stick to Motorcraft (FL400S) or Purlolator (L20195). Sometimes Amazon has the Purolator Tech (TL20195) filters for $2-$3. They appear to be the same product as their regular line of oil filters, except they are painted white instead of red..
black_demon69
142
AZ
4.0l
WIX or Napa gold for me. Napa filters are made by wix
RobbieD
2.9l Mafia
3,567
Georgia
I've only used Motorcraft filters on my RBVs and have never had an issue with them.
Sometimes there's an advantage in being a dinosaur and driving old stuff.
My '84, '90 and three '94's all take the same Motorcraft FL-1A oil filter. That's four different engines, to boot.
At my age it's nice having to remember only one part number . . .
lil_Blue_Ford
6,229
Butler, PA, USSA
4.9L
With the exception of my 3.0 Ranger and mom’s soon to be gone Murano, all of the vehicles around here take either the FL-1A or the FL-820s (essentially a short FL-1A). I try to buy them by the case when I can.
