Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
'93 Fords will have an oil pressure switch, so yes, jumping needle would indicate wire or switch issue.sorry to hijack, but Ron I have a hydraulic lifter sticking in the 93 4.0 ibelieve. But my oil pressure gauge shows pretty good pressure til i drive and then bounces around real bad, i figured bad sending unit. but i have ALOT of miles. any thoughts?
Thanks I will give atf a shot and see what it does.You could be correct. But you may not. And for a few dollars he will able to see if the lifters are ticking because they are bleeding down. If that does nothing, then there could be mechanical damage. I taught Autoshop for years, over 20. I certainly know what goes on within an engine. And if he has worn parts, then this won't help. But gummed up lifters is a common occurrence with engines that have the camshaft in the block. ATF has solved this problem too many times to count. So let' give it a try. It's certainly not a poor decision to try it. I'm not suggesting any additive to quiet it down, I'm talking about removing varnish from within a hydraulic lifter. Have you even taken one apart? I used to have an example mounted on the wall that I took apart so students could see the internal workings; not much there really But enough to get gummed up easily.
