Oh noes, teh Slave Cylinder again!
Twizzler09
19
Morrison, IL
4.2L/256CI V6
So it seems that every year or so.... I have to replace the slave cylinder in my truck due to it being rather leaky.
So far its gone through 3 slaves over the past 20k miles, any ideas on what can cause that? My first thought was the pilot bushing....dunno if that'd do it though.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Do you sit at stop lights holding in the clutch instead of leaving it in nuetral and foot off the clutch?
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
Don't ride the clutch, change the clutch fluid. Other than that, I have no idea why.
ElleShooTiger
Did you flush all the fluid when you last replaced it? Old dirty fluid remaining in the fluid line and master cylinder can destroy the seals on a new slave.
Twizzler09
19
Morrison, IL
4.2L/256CI V6
When the slave was replaced last time, there wasn't an ounce of fluid left in the whole system. It had been leaking at the time for a couple weeks, but then the throw-out bearing on it took a HUUUUUGE dump right in the middle of an intersection and left me without a workable clutch. Dumped every bit of fluid in the whole thing all over the street, lol.
I dont ride the clutch at stop lights, nor do I leave it in gear with the clutch pedal depressed for any length of time. The only odd thing I have been able to find/hear is occasionally at idle, and until the engine reaches 1,400rpm or higher, is like a rattle. Not the kind of rattle that comes from something like loose dashboard stuff, but it sounds kinda like a rattling bearing or something. All I know for sure is that the noise is directly RPM/engine load related.
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
hey matt i don't remember but has the pressure plate been replaced?
Twizzler09
19
Morrison, IL
4.2L/256CI V6
Thats a negative, Brian. I haven't ever replaced it, not that I can remember. It had a clutch replacement done years ago (2005) and it had 164k on the odometer at the time. Can't remember if the pressure plate was replaced then or not.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
I ride the clutch at stop lights and have only had one slave fail... that was sometime in 1998.... around 200,000 ago...
AD
Twizzler09
19
Morrison, IL
4.2L/256CI V6
I know Slaves don't normally fail this often or severely, so something is definitely messed up, but I haven't got a clue what it could possibly be.
One thing I *can* remember is a comment that was made by the mechanic that did the clutch work a few years ago, "For a hydraulic clutch, it sure takes alot of oomph to move that pedal. It seems pretty stiff."
Since then I've driven other manual trans vehicles, and I have to agree, mine does require a fairly significant amount more pressure to move the pedal. Not sure if that means anything though, could just be one of those little quirky things about my truck.
baddis
6
Avon,il
2014
next time you replace it try replacing the clutch and pressure plate
Twizzler09
19
Morrison, IL
4.2L/256CI V6
Guess I'll hafta try that when the chance comes up...which probably won't be for awhile, lol.
