OffRoad Upgrades
Boats12
I am starting a project pre-runner for my son. Truck is a 1999 2wd Ranger XLT. I have many questions but will start with a couple.. can I install the Camburg springs (5.5) without any other mods to the suspension. I already have a 3 inch spacer and longer than stock Bilstein shocks. Also, if I added a 3 inch spindle lift to that what happens to geometry of suspension?
JOLENE_THE_RANGER
204
long beach, ca
the taller sitting spring will add more angle to your upper arm ball joint almost maxing it out. the ride will be pretty shitty like that which is why they offer the kit with an upper control arm. the control arm (and spindle) gives you a uni ball at the top pivot so you have much more range of motion. the geometry wont change much when adding in the spindle. i believe even the factory SAI number is retained.
