- Aug 7, 2007
- 536
- Costa Mesa, CA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC
- 2WD / 4WD
- 4WD
- Tire Size
- 33"
I just spent a week on an off-road trip in Western Colorado and Eastern Utah. A issue came up that I have not experienced before. When going downhill in 4 WD low range and going around corners I would get this thump from the drivetrain with the truck slipping forward a little. It was almost like the like the transfer case chain was jumping a tooth. I installed a new chain in it last year so I doubt it is doing that. I also did a trip in the Maze Section of Canyonlands National Park last year after the transfer case work with no issues.
I am thinking it was from the transfer case binding up while going around the corner and suddenly releasing with a tire slipping. What I can't figure out is why it would not do it while going uphill around a corner. It could possibly be that the extra power used while going uphill would make the tires constantly slip to keep the binding to a minimum. I don't recall it doing it while on level ground either, only downhill. I am a little baffled because it has not done that before that I can remember.
I also thought the 33" tires could be contributing to it with the better traction, but I have been running them for many trips before without an issue. Normally, I would not be concerned about it but those thumps were more like bangs and seemed to be quite a shock to the drivetrain. So, I am throwing it out here to see if anyone has an idea why it suddenly popped up and things I could check out to diagnose it. I haven't had time to get under it yet, only a quick visual for anything that was very obvious.
