off pavement cherry picker
4
Oneida, Wisconsin
Mazda
3.0L
I am going to start swapping a 5.0L from a 2000 mountaineer into my 1999 Mazda B series with a 3.0L. But I have no blacktop or concrete to do this on and need a cherry picker that can go on gravel or dirt. Can anyone help me with this problem?
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
2 pieces of thick plywood. Just lay them down where you need to put the hoist and roll it along moving one piece in front of the other. Done it many times on gravel driveways.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
I had the same problem last year when I changed my engine. I fixed the problem by bolting larger wheels on my cherry picker.
The picture should be self explanatory. I hope this helps. The trailer Dolly allowed me to move the hoist with my quad.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I've done the plywood thing as well. But @Shadowrider6661 cherry picker would certainly add some fun to the job. (pushing the hoist around making revving engine sounds and burn outs in dirt just like the "dukes of hazard". :D)
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
Could also build an A frame to hang a chair fall from, roll the trucks in and out from under it.
racsan
4,490
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Have a tractor with a 3-point? put a boom on it and use that.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Junglejoe
66
Columbia Missouri
6.0
Pressure treated plywood works best
SenorNoob
584
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Strong friends? Pick it up and pack it. LOL.
snoranger
Professional money waster
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Weld a piece of 2” square stock onto the engine hoist. Slide it into your trucks receiver and run some ratchet straps to the front of the bed similar to this:
57645
Back up to the vehicle, pull the engine, then drive away with it.
SenorNoob
584
Middle Tennessee
245-70-R16
I LIKE that idea!(y)
