WackoRanger
- Jan 31, 2023
- 0
- Wisconsin
- Ford Ranger
- Engine Type
- 3.0 V6
Hello,
Shortly after I fixed the same 1997 Ford Ranger 3.0l Engine, the same problem came back after I replaced the PCM. For about 3 days I was able to run the truck completely normally and reliably. When I got in the truck to head home after work last night, it started having the same issue. The engine would start immediately, jump to 2K RPM, fall down to 1K RPM as it warmed up then eventually die. If I tried to apply any throttle, the engine would sputter and misfire as if I had a crossed spark plug wire (which I don't). When I applied the gas, it was like the engine was hitting the rev limiter and killing the ignition.
Anyways, I nursed it home without any throttle and I was able to get a read on the codes it was throwing.
P0174: System too Lean (Cylinder Bank 2)
P0171: System too Lean (Cylinder Bank 1)
P1445: Purge Flow Sensor Circuit High Input (To be expected, this engine is equipped with an EGR delete)
I also did a live data reading and found that as soon as any throttle was given to it, the O2 sensors would immediately die / give no output to the PCM.
So here's where I'm stuck. Previously, I was able to just let the engine warm itself up and it would mitigate this issue, which was annoying but I dealt with it, but now I have no ideas. With it being 25 degrees outside right now this truck really doesn't want to run and I don't really have any other reliable cars to use which makes this kind of urgent. Tomorrow I plan to check the junkyard for a new wiring harness from another 3.0. If that doesn't work, I'll check with some starting fluid for vacuum leaks and try and fix them. After that, I might throw the EGR system back on the engine and try it from there. Otherwise, I'm completely out of ideas. I have no explanation for why this stupid engine keeps killing PCM computers and I could really use some help.
__
WackoRanger
__
WackoRanger
