NP435/BW1345 pair in a 1gen Ranger?
Dlillie87
7
Florida
Ford/Ranger
I picked these up cheap as a pair. Will the tcase fit between the rails with a 3 inch body lift? I'd like to not have to find a different tcase.
68289
68290
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
If you search np435 in the search above it will lead you to others posts who have them
Dlillie87
7
Florida
Ford/Ranger
I'm asking about the tcase. I did use the search and it didn't pull anything up
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
yes it will fit between the frame rails. Body lift won’t effect where the drivetrain sits in relation to the frame.
Junk Collector
Truck of Month
4,802
Rapid City SD
It's going to be very tight if it fits at all. My 205 (which is much more compact) is a pretty close fit... I would measure from the center of the output shaft to the outer edge of the t-case, and apply that measurement to the space halfway between the frame rails and the inside of the driver's side frame.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Are you sure that’s a 1354? What did it come out of?
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
🤦🏼‍♂️ My bad. I mis read. I thought you said 1354. Disregard my stupidity.
