Northern aluminum raditator.how well do they work?
svtcards
137
Lyman maine
302
3'' front 4''back
R they valves or just connectors?what r they called?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
They are
Magical valvinators..
for valvinator stuff..
On a.serious note.
They are check valves.
svtcards
137
Lyman maine
302
3'' front 4''back
I've been using the Northern V8 conversion radiator since December of 2018 & it fits & works great. The Northern fits perfectly in the front supports. A small 14" 1,650 cfm electric fan kept the temperature between 185-195 degrees this summer even on 98 degree days with a 185 degree thermostat & temp switch. If the temperature was under 90 degrees outside my engine would run around 180-185. I may upgrade to a 16" fan, but haven't had any cooling issues so far.
I know this is an old post but.how much space did u have between the tip of your water pump and back of radiator? It looks like u have a ton of space? Also did u was a shorter style water pump to get that xtra space?
