Northern aluminum raditator.how well do they work?
bobbywalter
TRS Technical Staff
993
woodhaven mi
FORD mostly
BIGGER
sawzall?
so your saying 80s ranger pumps will bolt up to an sn95 power steering bracket?
If it's the RM 3 bolt noisy pos style.....yes.
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
Forum Moderator
3,373
SW Iowa
I've been using the Northern V8 conversion radiator since December of 2018 & it fits & works great. The Northern fits perfectly in the front supports. A small 14" 1,650 cfm electric fan kept the temperature between 185-195 degrees this summer even on 98 degree days with a 185 degree thermostat & temp switch. If the temperature was under 90 degrees outside my engine would run around 180-185. I may upgrade to a 16" fan, but haven't had any cooling issues so far.
Suppose there is enough room ahead of it for a A/C condenser?
svtcards
Active member
28
Lyman maine
3'' front 4''back
I made them with some angle aluminum from Tractor Supply & then polished them.
What did u use for your overflow tank.i c u have it right where charcoal cannister sits?where did u relocate cannister to?
insaneranger
37
Tennessee
302
225/40 R18
svtcards
Active member
28
Lyman maine
3'' front 4''back
Did u have to relocate your charcoal cannister?if so where did u put it?in process of this right now
svtcards
Active member
28
Lyman maine
3'' front 4''back
U took it off completely?so u have any gas smells at all?sorry the city dump answer threw me off a little?everyone's telling me it's needed if u don't want to smell gas while driving
insaneranger
37
Tennessee
302
225/40 R18
When I first got my truck back on the road you could smell gas when it was parked, but never while driving. I used to only have a dust filter on the fuel cell vent & it allowed a lot of fumes to escape. I added a couple loops in the vent line & it took care of the gas fume problem. Now there's no gas smell at all. I plan to upgrade to a better fuel cell & reroute the vent tube. When I upgrade the cell I may add a charcoal canister.
svtcards
Active member
28
Lyman maine
3'' front 4''back
So pretty much keep mine but relocate it.
Forum Moderator
3,373
SW Iowa
Explorers (and maybe second gens) have a bracket to mount it on the drivers side fender if that helps you any.
I haven't delved too deep into it but I would like to figure out some kind of standalone thing to vent the canister that doesn't require a computer. Not much info out there about such a lowly device and I have bigger fish to fry at the moment. Gas fumes are not horrible but in my quest to "make it look like it came that way" it is something on my radar.
svtcards
Active member
28
Lyman maine
3'' front 4''back
The cannister u mean?any idea what yr explorers?2nd gen 89-92?
svtcards
Active member
28
Lyman maine
3'' front 4''back
I meant 93-97 rangers
Forum Moderator
3,373
SW Iowa
That is a first gen (91-94) Explorer. 1993 to be exact.
A second gen Ranger (89-92) Ranger is kind of similar generally.
bobbywalter
TRS Technical Staff
993
woodhaven mi
FORD mostly
BIGGER
sawzall?
One on cannister intake.
One on feed to intake tube.
[/QUOTE]
svtcards
Active member
28
Lyman maine
3'' front 4''back
R these made for these cannisters?I think relocating it to the passenger side right across from where it is now may work.just need to get rid of the oem battery tray.its a mirror image of driver side where it mounts now.
bobbywalter
TRS Technical Staff
993
woodhaven mi
FORD mostly
BIGGER
sawzall?
They're for whatever you want them to be.
