No speaker outputs on Pioneer
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,798
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Im installing a Pioneer DMH-1770NEX stereo in my girlfriends vehicle. The stereo comes with a harness with RCA outputs for:
Front out left
Front out right
Rear out left
Rear out right
Subwoofer out left
Subwoofer out right
Rear monitor out
There's no 'speaker' wires.
If this was a home stereo I'd assume those were speaker outputs, but I've never seen RCA speaker outputs on a car stereo, and the instructions aren't clear.
Can anyone shed any light on thus type of setup???
snoranger
Professional money waster
ASE Certified Tech
13,693
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The RCAs area only used if you’re using external amps. There should be speaker wires on the same connector with the power input cable.
Pioneer uses:
L/F... white and white/black
R/F... grey and grey/black
L/R... green and green/black
R/R... purple and purple/black
Jim Oaks
Administrator
Supporting Vendor
8,798
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
You would think.
There are no speaker wires. Just a harness that plugs in with RCA outputs.
Here's what's in the box:
73360
The harness in the top middle is power connections. There's no speaker connections on it. The cord to the left has the RCA outputs. No speaker outputs.
Jim Oaks
Administrator
Supporting Vendor
8,798
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I need to look again. I think they're there. The directions lead me to believe it's a separate harness.
73362
snoranger
ASE Certified Tech
13,693
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
That’s strange. Pioneer usually uses its standard 16 pin connector for power in and speaker out.
How many wires are there on the power cable?
Bgunner
1,090
Western Mass.
Ford/Ranger XLT
225/70/R15
Well looking at the the provided picture and the wiring diagram your power connector has way more wires than just the Full time power, Switched power and Ground needed to provide power. The last pic provided shows the wiring for the speaker color codes. The power connector has your speaker wires, at least according to the pics and diagram provided.
If this connector is different than the pic provided can we get a pic of the connector and wires they provided you?
If you look at the speaker leads section you will see a group of wires coming off the connector with a squiggly line and dead ending, the same with power cord diagram. This is the separation of power and speaker wires on the same connector.
A little confusing I know but it is the same connector,
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
RobbieD
2.9l Mafia
3,542
Georgia
It looks like they screwed up and put a microwave oven in the box. Real radios have knobs and a door to stick in the 8-track tape. :)
ericbphoto
Overlander in development
16,686
Wellford, SC
6"
Looks similar to the Pioneer I put in my Fun50 a few years ago. Several connectors. I de-pinned and removed unused wires from the connectors to reduce the bulkiness behind the unit.
8,372
snoranger
ASE Certified Tech
13,693
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
:iamwithstupid:
Pioneer has used the same connector for years. The even used that connector on the pre-amp only head units. (With no speaker wires installed.)
It is possible that they shipped a pre-amp only harness. It would have the same 16 pin connector, but it would have no speaker wires and 8 empty spots.
Post a pic of the power connector you got.
superj
2,636
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
i think you can buy adapters to convert those rca to regular wires, too. and best buy sells a super tiny 400w amp that you could put them into and run the speaker wires out of the amp. that will be a heck of a surprise for the gf, ha ha ha
Jim Oaks
Administrator
Supporting Vendor
8,798
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
New morning and fresh eyes. I found all the connections on the harness. For some reasoni was looking g for a separate harness. This has multiple harnesses that have to be plugged in.
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
👆 What are we gonna do with this guy
Bgunner
1,090
Western Mass.
Ford/Ranger XLT
225/70/R15
I like the option of different harnesses because if you don't need the wires/connectors you can leave them out and have less clutter to try to manage in that small space they give you. I've run across times where stuffing wires behind the head unit made it difficult to flush mount the radio in the hole.
