No power to the cigarette lighter socket
Anthony2296
Dequeen Arkansas
I got no power to the cigarette lighter socket and the fuse is go
It’s a 2004 Ford Ranger 4.0
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Maybe it's broken
8,372
Just to confirm, Fuse #29, 20amp in the cab fuse box located in passenger side kick panel, powers both the Cigar Lighter and the OBD port
Anthony2296
Dequeen Arkansas
All fuses are good
Is there a way to test the cigarette lighter socket wire with a test light
sheep herder
1,024
sheep pen
If it ain't broke, break it.
This is the third thread you've started for the same problem. And none of them are in the correct section.
Anthony2296
Dequeen Arkansas
I'm beginning to hear a strange intermittent beeping sound "beeeeep......beeeeeep. goes on for 5-6 min. then just stops. any info ????( kinda sounds like when you first open your door but continues while driving)
Reply
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Could be a bomb?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
So Anthony... I moved your thread to electrical. You've had a couple threads going and we can better help you if you focus on one thread. Also... be complete with the symptoms you're having. Did you do recent repairs and then you started having problems? Did you sink it in a swamp? Did this problem show up out of nowhere. Lots of people are willing to help you...
Lets start you electrical issues over again. Right here...
ericbphoto
Overlander in development
16,686
Wellford, SC
3.0L
6"
All fuses are good
Yes. Attach the ground wire of your test light to the metal outer shell of the lighter socket and touch the probe to the center contact in the socket. If there is enough voltage, the test light should light up.
