that is true-but where do they bleed off to? something is wrong but no one knows where to go now
Lifters have a hole in the side where oil comes in from the passages, ONLY the oil pressure holds the oil IN the lifter, via that hole
When engine is shut off any oil, under pressure in the lifter, would come out that hole, nothing holding it in
Any engine oil system is "open ended", bearings and rocker assembly are all open where the oil comes out so any remaining oil pressure in the engine after its shut off just bleeds off pretty quickly
There is no way to "hold" oil pressure in an engine when the pump is off
Oil Pressure is the oil the engine CAN NOT USE at that moment, its back pressure
The Oil pump pumps more oil than the engine can use, as it should, so oil pressure you see at any time is the Back Pressure in the Main oil passage just after the oil filter
Oil pressure goes up with RPMs because Pump Volume goes up but engine doesn't need that much more oil, bearings, rocker assembly and lifter passages can only pass a limited volume of oil under any pressure, its why there is oil pressure to begin with
You forgot the "new" heads
Everything is "stock"
But something is wrong
CHECK THE PRE-LOAD, then take that off the table or................find out it is the issue
