Newbie here - Not a truck but needing Explorer Parking Brake Help
BDeTienne
Wichita, KS
Mercury Cougar
Hello All! First off let me say I hope you don't mind me bringing this here. While I do not have a Ranger this website was very helpful in helping me find the correct 8.8 rear for my application.
I own a 1967 Cougar with a fresh 347 and TKX 5 speed. Installed an Explorer 8.8 a few years ago when the original 8" broke. While the rear install went off pretty much without a hitch, the parking brake system was never installed. Finally decided it was time to get the parking brake functional when the car rolled over the "stop" i had behind the wheel and down my driveway last week. Damn near killed myself trying to get back into it and stop it before it hit the neighbors truck. Hoping that the crew of informed users here can point me in the right direction to get this thing working properly. I have nothing. No cables, etc. so I am going to need everything. Pic below is before/after I installed the CalTracs and the Calvert split mono-leaf rear springs on the 8.8.
Thanks in advance for your assistance.
Brian
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
That car is beautiful.
Is auto-phelia a thing? Because I might have it.
Good luck, I hope you get your answers you're looking for.
There is a green Cougar like this running around Tallahassee, but not nearly as mint as yours.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Don't think anyone will mind your questions on such a beauty.
Yep, best get ParkingBrake in order before you wreck that sweat ride.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
So I moved this to the brake forum to put it in the right area.
Maybe start with what type brakes you have... disc or drum?
Also... do you have the driver operated controls in place?
If it's a drum brake system... maybe consider a disc brake conversion. Even one that uses Eldorado calipers. Someone just posted a link to one kit that came with cables.
don4331
1,346
Calgary, AB
5.3
I suppose it's best not to assume he has Explorer discs as there was one year that the Explorer did come with drum (which might look more authentic on Cougar)
Either way, OP will want to start with the Explorer parking brake cables for the year of axle installed. Then we will want OP to pull the drums/rotors to see what is under the covers (picture worth 1k words).
BDeTienne
Wichita, KS
Mercury Cougar
Thanks for all the compliments. It is a nice driver but far from perfect. That's kind of the attraction. Don't go into panic mode whenever anyone gets near it.
Anyway...
Rear is in fact a disc brake rear and I put everything new when I put it together. Even new backing plates because the originals were damaged at the salvage. As I said in my original post I have none of the e brake components.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
LOVE THOSE COUGARS!!!!!
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
So... the rotor hat is also the brake drum. How much of the hardware inside the hat did you keep?
You mind find this article helpful...
BDeTienne
Wichita, KS
Mercury Cougar
Thanks for the link. It's been several years but if my memory isn't failing me I replaced everything inside the rotor hat.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
It sounds like you just need the cables then. I would try to match up the cables from an Explorer with a wheel base close to what your car has. It might take some fabrication to get it all to work together since the rear end isn’t stock.
