tidmarshsmiths5
- Jan 8, 2013
- 2
- South Carolina
- Ford
- Engine Size
- 2.8l stock
Just bought an April 1985 Bronco II.
Finally got water pump off (small leak), broke a bolt and a bolt on upper thermostat housing (that's where the thermostat is).
What is this "special refill procedure" I read about?
Gaskets or add a bunch of gasket sealer to make sure when I put the new water pump on and the upper thermostat housing? I was able to tap the bottom bolt I broke in the timing gear cover as torches, extractors, drills didn't work...should I use gasket sealer because whoever put the last one used a ton of gasket sealer. Also, the upper thermostat housing was full of sealer as well. I drilled through this one and will just have to use a bolt and nut to hold it.
clutch fan - should I replace or not...don't want to have to go through that ordeal to take off again (have over 15 hours invested in a 4 hour job)...I have never seen so much hassle to replace a water pump. I love the truck and even though my Dad had a brand new one in 1985, this is my 1st one (and I'm in my 40s).
