New member
Boga0911
U.S. Military - Active
6
USA
Ford Ranger XLT
Hello, new here have a project truck 2001 Ford Ranger XLT with about 72,500 miles. Looking for tips as I go through and make this truck right again.. all work done on my own in my garage…
having a custom front driveshaft built due to the lift, if anyone knows what bolts I need into the front transfer case it would be greatly appreciated!
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Welcome! Can't be too much that needs put right with those low of miles.
However.. going back to a factory intake would reward you with more usable power.
Boga0911
6
USA
Ford Ranger XLT
Yea, more than you would have thought!
Boga0911
6
USA
Ford Ranger XLT
Here’s a short this…
Optima yellow top battery
Rear Driveshaft
U-joints front and rear
Rear pinon seal and nut
Rear yoke
Front Driveshaft (custom for lift, pending build)
Front CV axles
CV axle seals
Front pinion seal
Front yoke
Front Hubs
Front brakes and rotors
Rear brakes and drums
Added rear view camera
New stereo w apple car play
Subwoofer
New speakers
New multifunction switch
LED high/low beams
LED rear lights
3rd brake light
Replaced all O2 sensor
MAF sensor
TPS sensor
Cleaned throttle body
Spark plug and wires
Ignition coil
Fixed exhaust leaks
EVAP sensor
Radiator core support
Radiator
Water pump
Serpentine Belt
Idler Pulley
Belt tensioner pulley
Bed lined entire truck and bed
Fuel pump and straps
All new stainless steel brake lines
All wheel studs
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Welcome to the site.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Good looking 2001 Ranger!
Consider renewing the 2 TimingTensioners in that V6~4.0L~SOHC,
& swapping in an Aluminum ThermoStatHousing;
both NotoriousFailureItems.
Boga0911
6
USA
Ford Ranger XLT
Thank you for the advice!
rumblecloud
1,120
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Geez...I got tired just reading the list.
Bedlined in lime green? Hold my beer...
