NEW member, old guy. Hello. This is my 1st post. XR4Ti eng. help.
waterran
NW Illinois
'92
R10
'92 Ranger. Have XR4Ti engine, want to keep using my factory A/C. Has anyone been able to keep the A/C compressor remaining on the top left side of the engine as installed from FORD on the n/a Ranger? I ask because I will likely have to buy a (forward turbo flange mount) aftermarket steel tubing exh. man. to clear the A/C plenum on the firewall. The '92 Ranger serpentine drive accessory setup will bolt directly to the turbo engine. I'm hoping someone has attempted to do this. Turbo intake/exhaust mounting clearance are my main concerns. If not, I will post my results. Thanks, waterran.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Not exactly my area, but the turbo coupes used the turbocharged lima engine and had factory AC. I'd be inclined to think the mounting brackets from the 83-88 coupes could work since the merkur engine is the same thing.
waterran
NW Illinois
'92
R10
There is an XR4Ti OE lower right hand mount A/C comp. avail in the aftermarket from RockAuto & others. I will use that & 'jury rig' or 'last Chance Garage' or 'Gubernickel Funknagel' the rest. Maybe some Yankee Ingenuity & Good Ole' Boy head scratchin' will accomodate my libation. Then...I can set a low E.T. on the way to WalMart!
waterran
NW Illinois
'92
R10
...more cannon Fodder...My newest idea for my '92 ranger w/ XR4 power is...95 or later PCM. These darlings contained the ICM (ign control module) inside the computer. Then...use coil on plug (COP) ignition from another FORD engine. This would eliminate the TFI module, distributor, plug wires. I haven't studied the '95 PCM pinouts to compare with the '85 Merkur XR4Ti PCM pinouts. Basically, I'm trying to emulate a high buck "STINGER" ignition by using Ford O.E. designs already in use. Any ideas? Thanks everybody.
waterran
NW Illinois
'92
R10
My '92 SOHC has a serpentine front engine accessory drive and A/C. I plan on using that setup. The location of the A/C Comp. (top left) & Alt. bottom rt.) are opposite XR4Ti. Thanks.
